PARAMETRICROTATEEDIT command
Edits parametric rotate operations.
Alias: PROTATEEDIT
Method
The command lets you edit an existing rotate operation.
Enter the name of the desired rotate operation, then select the parametric operation data to be edited.
Options within the command
- Shownames
Lists the names of all the rotate operations available in the drawing.
- Selection
Lets you edit the elements selection of the specified operation.
- Geometry
Lets you define a new operation geometry by selecting a rotation center point and rotation arc start and end points.
- Linked behavior
- Allows you to decide whether the entities will follow operation definition points when adjusted by other operations.Note: The Linked property can also be turned On or Off from the bottom section of the Mechanical Browser. The On value is signaled in Parameters Manager and Mechanical Browser panels by the symbol ∞.
Note: All editing options can also be accessed from the operation's right-click context menu in the Parameters Manager and Mechanical Browser panels.
