PIP command
Manages Python packages.
The command installs and manages custom Python packages.
Options within the command
- List
- Lists all installed Python packages.
- Install
- Installs the mentioned Python package.
- Uninstall
- Uninstalls the mentioned Python package.
- requirements File
- Installs or uninstalls dependencies as specified in the requirement.txt file.
Opens the Select requirements file dialog box to select the file.
- Freeze
- Generates or updates the requirements.txt file, which captures all installed dependencies and their versions.
