PLACEVIEW command
Imports named views from a source drawing.
Places named views from a source drawing into a paper space layout of the current drawing.
Note:
- This command works only in paper space, and is meant for use with sheet sets.
- It is not allowed to place a named view in a layout of the source drawing.
Method
There are two methods to place named views:
- Command line: start the command by typing placeview in the Command line.
- Mouse: drag a model view from the Content Browser panel onto a paper space layout.
Options within the command
- Enter file name
- Allows you to enter the file name from the source file from which the views will be imported.
- Enter view name to place
- Allows you to enter the name of the view you want to import.
- Prints a list of the named views in the Prompt History window.
- Enter view origin point
- Allows you to specify the location of the lower left corner of the named view.
