POINTCLOUDMODIFYCLASS command
Adds points to a point cloud class.
Allows you to select points in a point cloud to assign to a different class.
Note: Use the POINTCLOUDCLASSIFY command to automatically classify points in a point cloud.
Method
If the current drawing has more than one point cloud attached, you are first prompted to select one.
The indexes of the available classes are then listed in the upper field of the Command line.
Enter the index of the class under which the points will be classified.
You can immediately start selecting points based on the previously used selection type (shown as <default>) or change the selection type.
Select more points or finish the selection process.
Options within the command
- Rectangular
- Activates the rectangular selection type.
- Polygonal
- Activates the polygonal selection type.
- Finish
- Finishes the selection process and classifies the points.
