POINTCLOUDMODIFYBUILDING command
Adds a building or modifies existing ones.
Adds a new building (spatial classification) to the Buildings list in the Point Cloud Manager panel or modifies an existing one.
Options within the command
- Add
- Adds a new building. Lets you select a point cloud area to assign the points to the new building.Note: The Add Building option from the context menu of the Buildings category in the Point Cloud Manager panel runs the Add option of the POINTCLOUDMODIFYBUILDING command.
- Edit
- Modifies the volume of an existing building.
Specify the building index as listed in the Point Cloud Manager panel. Move the faces of the temporary crop solid.
Note: The Modify option from the context menu of a building listed in the Point Cloud Manager panel runs the Edit option of the POINTCLOUDMODIFYBUILDING command.
