-RENDER command
Renders 3D models.
Generates photo-realistic renderings of 3D models in a file or window and applies materials and lights if available. It works from the Command line.
Options
- Render preset
Choose a predefined preset rendering style or choose Other to select a custom preset created with the RENDERPRESET command:
- Draft: renders 3D models without ray tracing; fastest rendering speed.
- Low: renders with ray tracing set to level 3 (low).
- Medium: renders with ray tracing set to level 5 (medium).
- High: renders with ray tracing set to level 7 (high).
- Presentation: renders with ray tracing set to level 9 (highest); slowest rendering speed.
- Other: specify the name of a user-defined rendering preset.
- Render destination
Display the rendering in one of the following locations:
- File: saves the rendering as a BMP file in the folder defined by the DWGPREFIX system variable.
- Render window: displays the rendering in a separate window. The dimensions of the rendering are specified in pixels.
