REMOVESKETCHFEATURE command
Removes all sketch features at once but keeps the corresponding 3D solid.
Method
Specify if you want to remove or not all existing sketch features created when the CREATESKETCHFEATURE system variable was enabled.
Note: The corresponding 3D solids will remain.
