SPHERE command
Creates a 3D Solid in the shape of a sphere.
Icon:
Creates a 3D Solid in the shape of a sphere. Choose from a combination of options including center, radius and diameter.
- Center
- Radius
- Diameter
Note: In BricsCAD Lite, which doesn’t support 3D Solids, the SPHERE command launches the AI_SPHERE command.
Method
Specify the center of the sphere, then set the radius of the sphere.
Option within the command
- Diameter
- Specifies the diameter of the sphere.
