SSX command (Express Tools)
Creates a selection set based on a selected entity using filters.
Method
Creates a selection set that contains entities similar to or exactly the same as the selected entity.
Note: To access the selection set for a subsequent command, use the Previous selection option.
Options within the command
Block name
Allows you to specify a block name to add or remove from the selection filter.
Color
Allows you to specify a color number to add to or remove from the selection filter.
Entity
Allows you to specify an entity to add to or remove from the selection filter.
Flag
Turns the Entities follow flag On or Off.
Layer
Allows you to specify a layer name to add to or remove from the selection filter.
Ltype
Allows you to specify a linetype name to add to or remove from the selection filter.
Pick
Allows you to select an entity.
Style
Allows you to specify a text style name to add to or remove from the selection filter.
Thickness
Allows you to specify a thickness value to add to or remove from the selection filter.
Vector
Allows you to specify an extrusion vector to add to or remove from the selection filter.
