TINVOLUME command
Creates a TIN volume surface between a base and comparison TIN surfaces or an elevation.
Icon:
Method
When the TIN Volume Surface associativity option of the Civil / Associativity user preference is set, TIN volume surfaces automatically rebuild when their source surfaces change.
Select the base and the comparison TIN surfaces between which a TIN volume surface will be created and select a bounding area for the TIN volume surface.
Options within the command
- Elevation
- Creates a TIN volume surface between a base and an elevation.
Note: In the Properties panel of a TIN Volume Surface there are TIN Volume Statistics properties:
- Cut volume: reports the cut volume.
- Fill volume: reports the fill volume.
- Cut 2D area: reports the 2D area of the cut portions of the TIN Volume Surface.
- Fill 2D area: reports the 2D area of the fill portions of the TIN Volume Surface.
- Cut 3D area: reports the 3D area of the cut portions of the TIN Volume Surface.
- Fill 3D area: reports the 3D area of the fill portions of the TIN Volume Surface.
