VIEWBREAK command
Creates a break in a drawing view.
Icon:
Note:
- This command is available only in paper space and only for drawing views created by the VIEWBASE command.
- You can enter this command transparently while another command is active ('VIEWBREAK).
Method
Select the drawing view in which to create the broken view by clicking inside the view. Then select the first and second points to define the first and second cut planes.
The default symbol direction depends on the viewport dimensions:
- Vertical if the viewport is wider than it is high.
- Horizontal if the viewport is higher than it is wide.
Note: You can edit the grips of a Broken Symbol after placement. Click the symbol, select one of its two grip points and then place the grip point in a new location.
Options within the command
- Type
- Defines the Broken Symbol type.
- sTraight
- Sets the Broken Symbol type to a straight line.
- Spline
- Sets the Broken Symbol type to a spline curve.
- Zigzag
- Sets the Broken Symbol type to a zigzag line.
- sMall zigzag
- Sets the Broken Symbol type to a small zigzag line.
- Current
- Sets the symbol type to the currently selected type in the View Break Styles category of the Drawing Explorer dialog box.
Note: The properties of the symbol can be edited in both the Drawing Explorer dialog box and the Properties panel. See the VIEWBREAKSTYLE command article for more information.
- Vertical
- Aligns the symbol along the Y axis.
- Horizontal
- Aligns the symbol along the X axis.
