Add Surface Vertical Alignment dialog box
Opens via: ALIGNMENTVERTICALMANAGE command > Select Alignment dialog box > Manage Vertical Alignments dialog box > Add surface vertical alignment button
The Add Surface Vertical Alignment dialog box allows you add a surface to the vertical alignment.
Select surface
Allows you to select a surface from those available in the drawing.
