Auto Match dialog box
The Auto Match dialog box defines which characteristics of example entities are matched and lets you select a source. Opens via BIMAUTOMATCH command.
- Compositions
- Window Parameters
- BIM Properties
- Stair Parameters
- Select Source
Compositions
When checked on, the BIM properties of entities will be copied.
Entities without a composition will be matched with the other compositions in your drawing, based on type, spatial location and orientation of the entity, as well as on the 'Is external'-property.
If all entities have compositions, you can overwrite some by choosing a source entity. AutoMatch will then copy this source's composition to the rest of the valid entities.
Window Parameters
When checked on, the parameters of the windows will be copied.
If there are unchanged windows in your drawing, AutoMatch will match the properties based on width, height, type, spatial location and orientation of the windows and type and composition of the entities they are in.
- W (= width of the window)
- H (= height of the window)
BIM Properties
If there are entities with unchanged properties in your drawing, AutoMatch will match the properties based on BIM type, composition and spatial location of the other entities in your drawing.
If all entities have a changed property, you can overwrite it by choosing a source entity. AutoMatch will then copy this source's property to the rest of the valid entities.
Some general BIM properties will never be copied along:
- GUID
- Composition
- Profile
- SpatialLocation
- IsExternal
Some beam and column related BIM properties will never be copied along:
eomHash
athString
- XAxis
- YAxis
- ZAxis
- ProfileName
- EndPoint
- StartPoint
- Valid
- InstancePropertySets
Some window and door related BIM properties will never be copied along:
- Name
- SubtractAllSolids
- Translucency
- OverallWidth
- OverallHeight
Some slab related BIM properties will never be copied along:
- RoomBounding
Some room related BIM properties will never be copied along:
- Number
- RoomArea
- RoomRepresentation
Some stair related BIM properties will never be copied along:
- StairType
- NumberOfRisers
- NumberOfTreads
Stair Parameters
When checked on, the parameters of a stair will be copied.
If there are unchanged stairs in your drawing, AutoMatch will match the properties based on number of treads, number of risers, height, width, length and type of the stair.
- Height_Staircase
- Stair_Width
- Length_Staircase
Select Source
- Autocomplete
- Matches all chosen options for entities in the open drawing with similar entities in the open drawing.
- External file
- Opens the Select file to insert dialog box. Here you can choose a file to match all chosen options for entities in the chosen drawing with similar entities in the open drawing.
