Delete Duplicate Entities dialog box
The Delete Duplicate Entities dialog box allows you to delete duplicate entities and overlapping lines, arcs, and polylines, and unifies partly overlapping or contiguous ones. See also the related article OVERKILL command.
- Entity properties to ignore
- Comparison tolerance
- Options
- Duplicates
Ignores selected properties when comparing duplicate or overlapping entities.
Sets the tolerance for the comparison process. If set to 0 (zero), entities must match completely before being evaluated in the overkill process.
Options
Determines how special cases are handled.
- Maintain associative entities
- Associative entities are not processed.
- Ignore 3D solids
- Determines if duplicate 3D solids are ignored or removed.
- Optimize segments within polylines
Evaluates segments of selected polylines individually, duplicate vertices and segments are removed.
- Ignore polyline segment widths: ignores the Width property of overlapping polyline segments.
- Don’t break polylines: polylines entities are kept intact.
- Join collinear entities that partially overlap
- Unifies partially overlapping entities into a single entity.
- Join collinear entities when aligned end to end
- Unifies collinear lines and polylines having coinciding endpoints into a single entity or segment.
Duplicates
Determines what to do with duplicates: either delete them or move them to a Duplicate Entities layer.
