Edit GIS Layer dialog box
The Edit GIS Layer dialog box allows you to add, edit, or delete fields from an existing GIS layer.
- Name
- Geometry type
- Fields
- Add field
- Name
- Allows you to change the name of the GIS layer.
- Geometry type
- Allows you to change the geometry type of the GIS layer.
- Fields
- Allows you to change the name and type of a field or remove it.Note: Multiple selection is accepted by using Shift or Ctrl keys.
- Add field
- Allows you to add a field for GIS layer.
