Sheet Sets panel
To open the Sheet Sets panel:
  • Run the SHEETSET command.
  • Right-click a ribbon panel or toolbar and choose Sheet Sets from the Panels list.
The Sheet Sets panel offers a central location to create and to manage sheet sets.
  1. Current sheet set name
  2. Search
  3. Menu
  4. Create sheet set
  5. Open sheet set
  6. Publish
  7. eTransmit
  8. Sheet selection sets
  9. Custom properties
  10. Refresh
  11. Sheet list
  12. Category views
  13. Model views
  14. Sheet Sets list
  15. Details
Displays the name of the current sheet set. From the drop-down list you can change the current sheet set.
Search
Opens a search field that allows you to search for specific sheet set, subset or sheet names.
Menu
Opens a menu with a number of options depending on the sheet set panel state:
Import from XML
Allows you to import an XML file that was created in BricsCAD® with Export to XML.... Opens the Import Sheet Set dialog box.
Export to XML
Exports a sheet set in XML format. Opens the Export Sheet Set As dialog box.
Sheet Set Options
Opens the Sheet Controls options in the Settings dialog box.
Custom Properties
Allows you to add custom properties for sheet sets and sheets. Opens the Custom Properties dialog box.
Create sheet set
Opens the Create New Sheet Set dialog box.
Open sheet set
Opens the Select a Sheet Set file dialog box to select the DST file to be loaded. Click the right-side arrow to open a drop-down menu which contains a list with the recently opened DST files. Click one of these files to load the sheet set into the panel.
Open
Opens the selected DST file from the Select a Sheet Set file dialog box.
Publish
Publishes the currently selected sheet set(s), subset(s) or sheet(s) using the Publish dialog box. Click the right-side arrow to open a drop-down menu:
Publish
Publish to PDF
Publishes the currently selected sheet set(s), subset(s) or sheet(s) to PDF using the last used presets.
Publish to Plotter
Publishes the currently selected sheet set(s), subset(s) or sheet(s) using a plotter based on the last used presets.
eTransmit
Launches the ETRANSMIT command. The currently selected sheet set(s), subset(s) or sheet(s) are included in the eTransmit procedure. Opens the eTransmit dialog box.
Opens the Manage Sheet Selections dialog box. Click the right-side arrow to open a drop-down menu:
Manage...
Opens the Manage Sheet Selections dialog box where you can rename or delete Sheet selections.
Create
Saves the Sheet selection with a specified name.
List of existing sheet selection sets
Lists the existing sheet selection sets of the active (selected) sheet set in the panel. Click one of these items to activate the selection set.
Custom properties
Refresh
Updates all information stored in the sheet set data (DST) file, checks all folders in every resource location for new or removed drawing files, and all expanded drawing files for new or removed model space views.
Sheet list
Displays the Sheet Sets in the Sheet list mode.
Category view
Displays the Sheet Sets grouped by category.
Model views
  1. Add new location
  2. Folders
  3. Model views
Add new location
Opens the Browse for Folder dialog box to choose a folder to be added. Only unique folders can be added.
Folders
Lists all added folders that contain the drawings and their model views. The Model Views functionality allows you to browse and select model views (created with the VIEW command) from external drawings and insert them into the Paper Space layout of the current drawing, without opening the original file.
Note: The context menu opened by right-clicking a folder offers the option to Remove it from the Model views tab.
Model views
Model views (created with the VIEW command) from external drawings can be dragged and dropped into a Paper Space layout of the current drawing.
Note: Double-click a drawing/drawing Model view in the Model views tab to open it in the Model Space. Access the Open/Open Read-Only options from the right-click context menus.
Sheet Sets list
Displays the current sheet set.
When you change the project name in the BIM Project Browser panel, the Sheet Set name is updated correspondingly.
A Sheet Set can contain Sheets, Subsets, and Sheet Views.
Right-click menus offer additional tools:
Sheet Set
Close Sheet Set
Removes the Sheet set from the panel.
Export as XML
Resave All Sheets
Saves all sheets.
New Sheet(s)
Displays the New Sheet(s) dialog box, which allows you to add new sheets to the current sheet set.
New Subset
Adds a new subset to the current sheet set.
Selection Sets
Custom Properties
Renumber
Opens the Renumber Sheet Set dialog box, which allows you to renumber all sheets in the sheet set.
Plot
Plots the currently selected sheet set(s), subset(s) or sheet(s).
Publish
Opens the Publish dialog box.
Export Package (eTransmit)
Insert Sheet List Table
Inserts the sheet list table into the current drawing.
Sheet
Open
Opens the drawing with the layout of the selected sheet.
Open read-only
Opens the drawing with the layout of the selected sheet in read-only mode to protect it.
Remove Sheet
Removes the selected sheet.
Inserts a Sheet List Table in the drawing area.
Subset
Rename Subset
Allows you to rename the selected subset.
Remove Subset
Removes the selected subset.
Sheet View
Display View
Opens the drawing file related to the selected Sheet View.
Place Callout Block > Number Bubble
Places a callout block of the corresponding Sheet View.
Place View Label Block
Places a view label block of the corresponding Sheet View.
Note:
  • Double-click a sheet set or a subset to expand/collapse. Double-click a Sheet or a Sheet View to open it.
  • Sheet set tree nodes can be reordered using drag and drop.
  • The properties and variables of a selected Sheet Set, Subset, Sheet or Sheet View are displayed in the Details section.
Details
Displays the details of the selected Sheet Set, Subset, Sheet, or Sheet View. A preview of the selected sheets or subset can be shown or hidden.
In the Details > Sheet Set, the File path, View label block, Callout blocks and Total sheets options are read only, but selectable.
Note:
  • Click the Browse button () next to View label block option to open the Select Block dialog box.
  • Click the Browse button () next to Callout blocks option to open the Blocks List dialog box.
