BPARAMETERCOLOR system variable
Parameter Color
Controls the color of parameters in the Block Editor.
Type:
String
Saved in:
Registry
Default value:
170
Related commands
  • BACTION command
  • BACTIONSET command
  • BACTIONTOOL command
  • BEDIT command
  • BESETTINGS command
Related variables
  • BPARAMETERFONT system variable
  • BPARAMETERSIZE system variable
Related information
  • Dynamic blocks
Octave
