BACTIONTOOL command
Adds an action to a parameter in a dynamic block definition.
Disclaimer
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., the feature to create or edit dynamic block definitions is neither available nor licensed to you. Please see EULA for more information.
Method
You can add an action to a parameter in a dynamic block definition. The action defines how the selection set in the block geometry moves or changes when the action is triggered in a dynamic block reference.
Enter the action type, select the parameter to which to add the action, specify the selection set and the action location.
Options within the command
- Array
- Adds an array action to a linear, polar, or XY parameter.
- Lookup
- Adds a lookup action to a lookup parameter. Opens the Property Lookup Table dialog box.
- Flip
- Adds a flip action to a flip parameter.
- Move
- Adds a move action to a point, linear, polar, or XY parameter.
- Rotate
- Adds a rotate action to a rotate parameter.
- Scale
- Adds a scale action to a linear, polar, or XY parameter.
- sTretch
- Adds a stretch action to a point, linear, polar, or XY parameter.
- Polar stretch
- Adds a polar stretch action to a polar parameter.
