BACTIONSET command
Specifies the selection set of entities for an action in a dynamic block definition.
Icon:
Disclaimer
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., the feature to create or edit dynamic block definitions is neither available nor licensed to you. Please see EULA for more information.
Method
Select the action, then define a new selection set for the action or modify the existing one.
Options within the command
- New
- Defines a new selection set of entities on which the action is applied.
- Modify
- Specifies the entities to be added to or removed from the action's existing selection set.
- Add
- Adds the selected entities to the selection set.
- Remove
- Removes the selected entities from the selection set.
- CPoligon
- Defines the boundary area of an action (the entities modified by the action) by the specified polygon.
- Undo
- Undoes the last polyline segment and continue drawing from the previous point.
