COMMANDASSIST system variable
Predict Command line
Controls the use of personalized command suggestions.
Only possible if Application Data collection is enabled in the DATACOLLECTIONOPTIONS system variable.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Range: |
Off |
| Possible values: |
Off (0): Do not enable Predict Command line On (1): Enable Predict Command line |
