DATACOLLECTION system variable
Diagnostics and usage data collection
Controls the sharing of anonymous usage data.
This helps personalize the program and significantly enhances the user experience for everyone.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
-2 to 1 |
| Default value: |
1 |
| Possible options: |
-2: Not asked -1: Not set 0: Off 1: On |
Note:
- Sharing data anonymously is possible only if the user is not logged in and System and Settings Data, Application Data or Anonymized Geometry is enabled in the BricsCAD Analytics Program dialog box or the DATACOLLECTIONOPTIONS system variable.
- The current data sharing status is indicated by the DATACOLLECTIONENABLED system variable.
