DATACOLLECTIONOPTIONS system variable
Data Collection Options
Controls what anonymous data is shared.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 11 |
| Default value: |
0 |
| Possible values: |
0: Nothing 1: System and Settings Data 2: Application Data 8: Anonymized Geometry |
Note:
- Sharing data anonymously is possible only if the user is not logged in and System and Settings Data, Application Data or Anonymized Geometry is enabled in the BricsCAD Analytics Program dialog box or the DATACOLLECTIONOPTIONS system variable.
- Trial users must sign in to use BricsCAD and, by default, participate in the BricsCAD Analytics Program, sending system, settings and application data.
- Licensed users do not need to sign in and, by default, do not participate in the program or send this data. However, users who previously used a trial version and then activated a license retain their sign-in status and data collection settings, and therefore continue to participate in the program and send data unless these settings are changed.
