DATACOLLECTIONENABLED system variable
Current state of data collection (Read Only)
Controls diagnostic and usage data collection.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Not saved |
| Range: |
Off |
| Possible values: |
Off (0): Data collection is disabled On (1): Data collection is enabled |
Note: The value of this system variable is by default based on the value of the DATACOLLECTION preference variable, however it is possible to override the default by applying an administrative override. The administrative override is applied by manually adding the registry value in HKLM\Software\Bricsys\BricsCAD\V26x64\AdminPolicy.
To add this override follow the next steps:
- Go to: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Bricsys\BricsCAD\V26x64.
- Right-click the V26x64 key and choose and rename it to AdminPolicy.
- Right-click on the new created key and choose and name the value DATACOLLECTIONENABLED.
- Change its value to 0 or 1 to override the value of DATACOLLECTION user preference.
