SELECTIONMODES system variable
Selection modes
Controls what is selected by default: whole entities, subentities or boundaries.
Use the TAB key, on hover, to cycle through the options.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: | 0 to 15 |
| Default value: | 0 |
| Possible options: | 1: Select edges 2: Select faces 4: Select detected boundaries 8: Select vertices |
