SPAGRIDASPECTRATIO system variable
Grid aspect ratio
Controls the aspect ratio of each cell in a grid. Ignored if the FACETRES system variable is in use.
A value of 1 is square.
This does not guarantee the aspect ratio of the facet, which may consist of only a part of a cell.
Note: Spa is short for Spatial, the maker of ACIS.
BricsCAD only
| Type: | Real |
| Saved in: | Preference |
| Default value: |
0.0 |
