SPAGRIDMODE system variable
Grid mode
Controls how grids are used in the mesh process. This variable is ignored if FACETRES is used.
The grid mode specifies whether a grid is used and whether the points where the grid cuts the edges should be inserted into the edge discretization.
Note: Spa is short for Spatial, the maker of ACIS.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 3 |
| Default value: |
1 |
| Possible options: |
0: Do not subdivide faces with a grid 1: Use a grid but do not add model edge intersection points 2: Allow grid to divide model edges 3: Grid only in one direction, u or v |
