-MODELERPROPERTIES command
Manages ACIS modeler settings via Command line.
Specifies settings for the ACIS modeler.
Method
Select options available in Command line to view or modify settings for the ACIS modeler.
Note: If the SPAUSEFACETRES system variable is On, the configuration relies on FACETRES system variable, and the other settings for the ACIS modeler are ignored.
To adjust the Hidden Line Accuracy setting, use the MODELPROPERTIES command.
Options within the command
- view Properties
- Reports the value of each setting.
- USe facetres
- Sets the SPAUSEFACETRES variable. If activated, it reads the value of the FACETRES variable to set the smoothness of shaded and rendered scenes.
- Surface tolerance
- Sets the value for the SPANORMALTOL variable.
- Normal tolerance
- Sets the value for the SPASURFACETOL variable.
- Max grid lines
- Sets the value for the SPAMAXNUMGRIDLINES variable.
- Edge length
- Sets the value for the SPAMAXFACETEDGELENGTH variable.
- grid aspect Ratio
- Sets the value for the SPAGRIDASPECTRATIO variable.
- Adjust mode
- Sets the value for the SPAADJUSTMODE variable.
- Grid mode
- Sets the value for the SPAGRIDMODE variable.
- Triangulation mode
- Sets the value for the SPATRIANGMODE variable.
- min U grid lines
- Sets the value for the SPAMINUGRIDLINES variable.
- min V grid lines
- Sets the value for the SPAMINVGRIDLINES variable.
- mass properties aCcuracy
- Sets the value for the MASSPROPACCURACY variable.
- check Level
- Sets the value for the SPACHECKLEVEL variable.
