SPAMAXFACETEDGELENGTH system variable
Maximum facet edge length
Controls the maximum length of a facet side. Ignored if the FACETRES system variable is used.
A value of zero means uses defaults (recommend).
CAUTION: Lengths that are too small cause high memory consumption and poor performance.
BricsCAD only
| Type: |
Real |
| Saved in: |
Preference |
| Default value: |
0.0 |
