SPAMINUGRIDLINES system variable
Minimum number of U grid lines
ontrols the minimum number of U grid lines - the minimum number of grid lines generated in the U direction. Ignored if the FACETRES system variable is in use.
Note: Spa is short for Spatial, the maker of ACIS.
BricsCAD only
| Type: | Long |
| Saved in: | Preference |
| Default value: |
0 |
