ALINEARVISTA comando
Crea una vista de alineación vertical para la alineación horizontal seleccionada.
Ícono:
Método
Se abre el cuadro de diálogo Seleccionar Alineación para seleccionar una alineación horizontal.
Luego, se abre el cuadro de diálogo Crear Vista de Alineación Vertical.
Vertical Alignment View information
Specifies the vertical alignment view details.
- Name
- Sets the name of the new vertical alignment view.
- Layer
- Sets the layer on which the vertical alignment view is created. Click the field to open the drop-down list with available layers.
- Style
- Sets the style for the vertical alignment view.
Click the Select or edit style... button (
) to open the Select Style dialog box. To edit the current style, click the Edit style... button to open the Vertical Alignment View Style dialog box. To create a new style, copy an existing style.
- Horizontal alignment
- Displays the horizontal alignment name associated with the vertical alignment view.
- Frame settings button
- Opens the Frame Settings dialog box to define the view frame dimensions.
Vertical alignments
Lists which vertical alignment objects are displayed in the vertical alignment view.
- Manage vertical alignments button
- Click the (
) button to open the Manage vertical alignments dialog box, where you can edit the vertical alignments.
- Object
- Lists available vertical alignment objects grouped by source type (for example, Surface or Layout).
Only checked objects are displayed in the vertical alignment view.
- Update mode
- Displays how the vertical alignment updates when its source changes.
- Data source
- Displays the source used to create the vertical alignment.
- Clip gridlines to
Toggles the option to choose the vertical alignment used for clipping gridlines from the drop-down list.
