Create Material List dialog box
Opens via: CALCULATESECTIONVOLUMES command
The Create Material List dialog box allows you to define the material name and to select the base surface and the comparison surface.
Material list name
Allows you to define a material name.
Base surface
Allows you to select the base surface from the drop-down list of the available surfaces, or select it directly from the drawing area.
Comparison surface
Allows you to select the comparison surface from the drop-down list of the available surfaces, or select it directly from the drawing area.
