Select Surface dialog box
Opens via: CALCULATESECTIONVOLUMES command > Calculate Section Volumes dialog box > Add definition button
The Select Surface dialog box allows you to select a surface.
Select surface
Allows you to select a surface from the drop-down list of available surfaces, or select it directly from the drawing area.
