Vertical Alignment View Style dialog box
Opens via:
- Civil Explorer panel > Settings tab > Vertical Alignment View Styles context menu > Create or Edit options
- Select Style dialog box > Edit style... button
The Vertical Alignment View Styles dialog box defines how a vertical alignment view is displayed in a drawing.
Info tab
Displays information about the vertical alignment view style.
- Name
- Sets the vertical alignment view style name.
- Description
- Sets the description of the vertical alignment view style.
- Details
- Displays Last saved by and Last saved dates.
Settings tab
Defines general vertical alignment view style settings.
- Vertical scale
- Defines the vertical scale used in vertical alignment views.
- Gridline padding (minor gridline)
- Specifies the margin, measured in minor gridline intervals, around the vertical alignment view extents.
- Top
- Sets the distance from the top edge of the frame to the gridlines.
- Bottom
- Sets the distance from the bottom edge of the frame to the gridlines.
- Left
- Sets the distance from the left edge of the frame to the gridlines.
- Right
- Sets the distance from the right edge of the frame to the gridlines.
Labels tab
Adds and manages the vertical alignment view labels.
- Add new component button
- Adds a new Text component defining the section view style.
To add a Block component to the list, click the arrow on the right side of the button to open the drop-down list and choose Block.
- List of components
Lists the components of the vertical alignment view labels.
- Component name
- Displays the components names.
- Anchored to
- Defines the position (anchoring) dependency between vertical alignment view components.
A component can be aligned either relative to the selected edge of the vertical alignment view frame or relative to another component.
The alignment options include:
- <Axis Top> – aligns the component with the top horizontal edge of the frame.
- <Axis Bottom> – aligns the component with the bottom horizontal edge of the frame.
- <Axis Left> – aligns the component with the left vertical edge of the frame.
- <Axis Right> – aligns the component with the right vertical edge of the frame.
- All other text and block components listed – select one to align the current component to.
- Anchor point
- Defines the anchor point of the component on the selected edge of the vertical alignment view frame, or on the dependent component to which it is anchored.
Click the Anchor point field or the arrow on the right to the field of a component to open a drop-down list of available positions.
When aligning a text or block to an axis, you can specify its exact position on the frame edge.
- Left – attaches the component to the left side of a horizontal axis.
- Center – attaches the component to the center of a horizontal axis.
- Right – attaches the component to the right side of a horizontal axis.
- Top – attaches the component to the top side of a vertical axis.
- Middle – attaches the component to the center of a vertical axis.
- Bottom – attaches the component to the bottom side of a vertical axis.
When aligning a text or block to another component, you can place it on the chosen anchor point of that component.
- Top left – attaches the component to the top left side of the anchor point.
- Top center – attaches the component to the top center side of the anchor point.
- Top right – attaches the component to the top right side of the anchor point.
- Middle left – attaches the component to the left center side of the anchor point.
- Middle center – attaches the component to the center of the anchor point.
- Middle right – attaches the component to the right side of the anchor point.
- Bottom left – attaches the component to the bottom left side of the anchor point.
- Bottom center – attaches the component to the bottom center side of the anchor point.
- Bottom right – attaches the component to the bottom right side of the anchor point.
- Visible
- Turns on or off the visibility of the component.
- Remove
- Removes the component.
Note: To change the order of the list, select a column header and drag it to a new position.
- Components properties
- Defines the properties of the text or block components.
- Text
- Label contents
- Displays the content of the text component label.
Click the Edit button to open the Text Content Editor dialog box to add, edit or remove attributes displayed in the label. See the Text Content Editor dialog box for more information.
- Attachment
- Sets the position of text components relative to the selected point. Click the field to open a drop-down list with the available positions.
- X offset
- Specifies the offset of the text component from the symbol in the X direction.
- Y offset
- Specifies the offset of the text component from the symbol in the Y direction.
- Text rotation
- Sets the rotation angle of the text component. The default rotation angle is 0.
- Text style
- Specifies the text style used for the text component.
- Text Height
- Sets the height of the text components.
- Color
- Sets the color of the text component.
- Plot style
- Sets the plot style of the text component.
- Border
- Defines the border of the vertical alignment view frames.
- Visibility
- Turns on or off the visibility of the vertical alignment view frames.
- Background mask
- When on, adds a white background.
Horizontal axis tab
Manages the horizontal intervals and labels for horizontal gridlines in vertical alignment views.
- Gridlines
- Sets the gridline values.
- Major interval
- Sets the spacing of major gridlines.
- Minor interval
- Sets the spacing of minor gridlines.
- Tick and label origin
- Sets the visibility of tick marks and labels at the origin. Select the checkbox to turn on the visibility.
- Horizontal geometry labels
- Defines labels for the horizontal geometry.
- Visibility
- Toggles the visibility of the labels.
- Label content
- Displays text content of the label.
- Position
- Sets the position for the label relative to the gridlines.
- X offset
- Sets the offset of the label from the insertion point in the X direction.
- Y offset
- Sets the offset of the label from the insertion point in the Y direction.
- Text rotation
- Sets the rotation angle of the label text. The default value is 0.
- Text style
- Specifies the text style used for the label text.
- Text height
- Sets the height of the label text.
- Color
- Sets the color of the label.
- Plot style
- Sets the plot style from the drop-down list of available plot styles.
- Major labels
- Defines the labels for major gridline intervals, using the same settings as for the Horizontal geometry labels above.
- Minor labels
- Defines the labels for minor gridline intervals, using the same settings as for the Major labels above.
Vertical axis tab
Manages the vertical grid intervals and labels for vertical gridlines in the vertical alignment views.
For a detailed description, see the above Horizontal axis tab section.
Display tab
Manages the visibility and display characteristics of each component in vertical alignment views.
- To sort the list in either ascending or descending order, click the title in the column heading.
- Right-click any column heading to open a context menu, from which you can hide unnecessary columns or reset the columns to their original positions.
- Lists vertical alignment view components with assigned visibility and layer.
