COMMUNICATORINFO command
Checks whether the Communicator add-on is correctly installed and provides a diagnostic report.
The command is available on Windows only.
Until V21, the major versions of BricsCAD and Communicator should match (e.g. Communicator V20.2.x works with BricsCAD V20.2.x).
Starting with V21 the compatibility between minor releases is supported (e.g. Communicator V21.1.x will work with BricsCAD V21.2.x).
Switches to the Prompt History window and then provides a report.
When Communicator is not installed, then the command reports:
Brief check result: Communicator installation: FAILED
