Creates an angular dimension by selecting an entity or specifying the vertex and both
sides of the angle. The dimension is based on the current dimension style. Options
allow you to specify the angle and contents of the dimension text.
Methods to create an angular dimension
This command has 2 methods to begin creating an angular dimension:
Select line, arc, or circle
Press ENTER to specify angle
Select line, arc or circle
Begin creating an angular dimension by selecting a line, arc, or circle
to dimension then:
Additional options: [selection options (?)]
If you selected a line or line segment
Other line for angular dimension
Specify another line segment.
Location of dimension arc
Specify the location of the dimension arc.
Additional options: [Angle/Text]
If you selected an arc or arc segment
First side of angle
Other side of angle
Vertex of angle
If you selected a circle
Other side of angle
Specify a point to define one side of the angle.
The point where you first selected the circle defines the other side of
the angle.
Select circle
Other side of circle
Vertex of angle
Begin creating an angular dimension by specifying the vertex of the
angle then:
First side of angle
angle.
Other side of angle
Specify a point to define the other side of the
angle.
First side of angle
Other side of angle
Vertex of angle
Options within the DIMANGULAR command
After you begin creating an angular dimension, the following options may be
available:
Angle
Specify the angle of the dimension text. A value of 0 aligns the
dimension text with the dimension line. Any other value rotates the
dimension text relative to the x-axis of the current UCS.
Text
Enter text to override the default dimension text which includes the
measured length of the dimension. You can use two angle brackets
<> to display the measured length of the dimension in addition to
other text.
DIMANGULAR command - BricsCAD Lite & Pro | Centro Assistenza Bricsys
