POINTCLOUDCOLORMAP command
Colorizes the point cloud.
Icon:
Colorizes the point cloud based on a range of colors.
Options within the command
Scan
Assigns color based on the color data collected by the scan.
Elevation
Assigns color based on the elevation of the points using a specified color map.
Spectrum
Assigns a range of colors based across the color spectrum.
Earth
Assigns a range of colors from light brown to dark brown.
Hydro
Assigns a range of colors from light blue to dark blue.
grAy
Assigns a range of colors from light gray to dark gray.
Reds
Assigns a range of colors from light red to dark red.
Greens
Assigns a range of colors from light green to dark green.
Blues
Intensity
Assigns colors according to their intensity value based on the specified color map.
Note: When the point cloud file contains no intensity data, then the colors are assigned by height, regardless of which option you select.
PlaneDeviation
The deviation colors points in the point cloud according to their distances to the selected planes.
Note: This option is used to verify how well points fit with given or fitted entities.
Note: The colors are influenced by the two tolerance levels: Plane Tolerance OK and Plane Tolerance Warning. They can be found in the Properties Panel . All points that are on a distance less than Plane Tolerance OK from the plane, are colored green. Points that are on a further distance than Plane Tolerance OK, but smaller than Plane Tolerance Warning, are colored orange (on one side of the plane) or light blue (on the other side of the plane). Points that are even further than Plane Tolerance Warning are colored red (on one side) or dark blue (on the other side).
Note: This option works with regions, surfaces and solids.
