Civil commands
The Civil commands are listed in the table below:
| Name | Title | Description |
| Open the Civil Explorer panel. | Opens the Civil Explorer panel to display it in the current workspace. | |
| Close the Civil Explorer panel. | Closes the Civil Explorer panel to hide it from the current workspace. | |
TIN Surface |
Creates a topographical (TIN) surface. |
Edit TIN Surface |
Adds or removes points, breaklines or boundaries on a TIN surface. |
Modify TIN Surface |
Deforms or smooths a TIN surface. |
| TINMERGE command |
Merge TIN Surfaces |
Combines two or more TIN surfaces into a single TIN surface. |
| TINASSIGNIMAGE command |
Assign Image to TIN Surface |
Assigns a raster image to a TIN surface, as a material. |
| TINPROJECT command |
Project to TIN Surface |
Projects points (points, blocks and text) or linear entities (lines, polylines and circles) to a TIN surface. |
| TINEXTRACT command |
Extract from TIN Surface |
Extracts meshes, solids, points, faces, contours or borders from a TIN surface. |
| TINWATERDROP command |
Water Drop |
Creates a water drop path on a TIN Surface. |
| GRADING command |
Grading |
Creates a graded surface on a TIN surface. |
| GRADINGEDIT command |
Grading Edit |
Splits or merges gradings. |
| GRADINGBALANCE command |
Balance Grading Volumes |
Balances grading cut and fill volumes. |
| TINVOLUME command |
TIN Volume Surface |
Creates a TIN volume surface between a base and comparison TIN surface, or an elevation. |
| ADDSURFACELABELS command |
Add Surface Labels |
Adds spot elevation labels, slope labels or contour labels on a surface. |
| CIVILPOINT command |
Civil Points |
Creates civil points (civil entities) represented by symbols and labels. |
| CIVILPOINTGROUP command |
Civil Points Groups |
Creates civil point groups. |
| CIVILPOINTATTRIBUTES command |
Civil Point Attributes |
Adds or removes user-defined attributes, to civil points. |
| ALIGNMENT command |
Alignment by PI |
Creates horizontal, vertical and 3D alignments. |
| ALIGNMENTLINE command |
Alignment by Element - Line |
Creates an unconstrained, horizontal, line alignment. |
| ALIGNMENTCURVE command |
Alignment by Element - Curve |
Creates an unconstrained, horizontal, curve alignment. |
| ALIGNMENTELEMENTFROM command | Alignment by Element - To/From Element |
Creates a horizontal alignment, constrained on one side by another element. |
| ALIGNMENTELEMENTBETWEEN command |
Alignment by Element - Between Elements |
Creates a horizontal alignment constrained on both sides by other elements. |
| ALIGNMENTEDIT command |
Edit Alignment |
Edits a horizontal or vertical alignment. |
| ALIGNMENTVIEW command |
Vertical Alignment View |
Creates a vertical alignment view for a horizontal or 3D alignment. |
| ALIGNMENTVERTICAL command |
Vertical Alignment |
Creates a vertical alignment. |
| ALIGNMENT3D command |
3D Alignment |
Creates a 3D alignment from horizontal and vertical alignments. |
| CORRIDOR command |
Corridor |
Creates a corridor from a corridor template. |
| CORRIDOREDIT command |
Edit Corridor |
Adds or removes a corridor region. |
| CORRIDOREXTRACT command |
Extract from Corridor |
Extracts 3D solids, meshes, TIN surfaces, 3D polylines or outer boundaries, from a corridor. |
| CORRIDORTEMPLATE command |
Corridor Template |
Creates a corridor template. |
| CORRIDORTEMPLATEELEMENT command |
Corridor Template Element |
Creates a corridor template element from closed polylines. |
| CORRIDORTEMPLATEELEMENTEDIT command |
Edit Corridor Template Element |
Adds or removes components to corridor template elements. |
| CIVIL3DIMPORT command |
Import Civil 3D |
Imports objects from a Civil 3D drawing. |
| LANDXMLIMPORT command |
Import LandXML |
Creates TIN surfaces or alignments from a LandXML file. |
| GISIMPORT command |
GIS Import |
Imports spatial and attribute data from an ESRI SHP file. |
| IFCEXPORT command |
Export to IFC |
Exports the model to an IFC file. |
| LANDXMLEXPORT command |
Export LandXML |
Exports Civil entities to a LandXML file. |
| GISEXPORT command |
GIS Export |
Exports spatial and attribute data in an ESRI SHP file. |
| CIVILDWGEXPORT command |
Export DWG |
Exports civil objects as native DWG entities. |
| MAPTRIM command |
Boundary Trim |
Trims objects to a boundary: closed polylines, circles, closed splines or ellipses. |
