Predict
The Predict Ribbon provides suggestions based on your personal BricsCAD usage, and similar users. The Predict tab has two states: an empty state and a populated state.
You can add or remove the Predict Ribbon tab by removing or adding it to the CUI file.
The Predict tab in the empty state
- Sign Up
- The Sign Up button opens the BricsCAD Analytics Program dialog box. See the BricsCAD Analytics Program article for more information.
The Predict tab in the populated state
- Analytics Settings
- The Analytics Settings button opens the BricsCAD Analytics Program dialog box.
- Other Command Suggestions
- Displays commands used by other users with similar interest as yours.
You will get generic suggestions based on the workspace, and license level from the first day of usage.
- Personal Command Suggestions
- Displays the most important commands used.
Note: Panels will be populated from the first day of usage BricsCAD with commands based on your interaction with BricsCAD via Quad, command line, Ribbon, menu, and toolbars. Also, not everyone will be eligible for all models, depending on how we categorize them.
- Next Commands
- Dynamically displays some predicted commands which could be used by the user after the current command.
