BIMCOLLECTDETAILS command
Collects all tagged BIM details from the active sheet and inserts layouts of these details on the sheet.
BricsCAD BIM
Method
After it collects all tagged BIM details from the active sheet, it inserts layouts of these details on the sheet. For details with multiple layouts, name a layout to be inserted. Specify the base and second insertion points for the layout.
The inserted layout will hold a pointer to the detail source. This additional information allows BIMCHECKDETAILS command to list and interact with the inserted layouts of the project details.
Note: This command is available only in a BIM Project sheet.
