BIMIFY command
Analyzes the model and runs automatic classification and spatial location assignment for the entire model.
Icon:
Analyzes the model and runs an automatic classification and spatial location assignment for the entire model. Creates new buildings and/or stories and spaces if necessary. Optionally creates plan sections and elevations.
- Section entities are converted to BimSection entities.
- Simple block references can be classified.
Method
Running BIMIFY command on the entire model will classify objects, assign spatial locations, detect spaces and create elevations and floor plan section planes in the model.
When the BIMIFY process is completed, an overview of the result is provided in the Command line.
This command opens the Bimify command panel.
- When creating new buildings, the DEFAULTSTORYNAMINGSCHEME system variable defines the naming and numbering of the spatial elements. You can access this info in the Spatial Locations Manager dialog box.
- When adding new stories to an existing building, the Story Naming Scheme property of the building overrides the value of the DEFAULTSTORYNAMINGSCHEME system variable.
- With the Story Bar open (STORYBAR system variable is set to 1 or 2), you can easily switch between the defined floors in Top View Mode to start creating walls.
The Bimify command panel allows you to analyze the model and run an automatic classification and a spatial location assignment for the entire model.
- Entities
- Options
- Feedback
- Entities
- Select entities in drawing
- The BIMIFY command runs for the selected entities in the drawing.
- Options
- Discipline
- Determines to what discipline the model belongs in order to improve the automatic classification.
- Feedback
- Keep panel open and show results
If toggled On, the panel will show the progress and results while calculating.
Note: This option is Off by default for consistency with previous versions.
