BIMLINEARSOLID command
Creates a chain of linear solids.
                Icon:
Options within the command
- Set start point
- Allows you to set a starting point for the linear solid. You can also use Last point and Follow as a starting point.- Angle
- Draws at a user-specified angle and distance.
 - Length
- Draws at a user-specified distance and angle.
 - Undo
- Erases the last linear solid.
 - Quarter turn
- Rotates the profile 90° counter clockwise.
 - Rotate
- Allows to rotate the profile by a user defined angle.
 - choose other Profile
- Allows to use a different profile for the next linear solid.
- Last point
- Press Enter to use the most recently specified point.
- Follow
- Draws the next linear solid at the same angle as the previous one.
- Rectangular
- Switches to a default rectangular profile.
- Circular
- Switches to a default circular profile.
- Library
- Opens the Profiles dialog box.
- select in Model
- Allows to select a profile in the model.
- adJust profile
- Allows to adjust the dimensions of the default rectangular and circular profiles.Note: For the rectangular profile you can change the width and the height, and for the circular profile you can change the radius.
