BIM Profiles panel
The BIM Profiles panel offers a central location to access standard and custom profiles.
- Menu
- Domains
- Standards
- Search bar
Menu
- Open material dialog...
- Opens the Physical Material dialog box that allows you to create, modify and delete physical materials.
- Open profile dialog...
- Opens the Profiles dialog box that allows you to create, modify and delete profiles
- Open project dialog...
- Opens the BIM Project Info dialog box that allows you to import profiles with XML/CSV files in the project database, control the location, properties, and content of the Project and Central databases.
- Show only profiles in project
- Displays only the profiles that are used in the project.
Domains
Filters profiles based on the domain.
Standards
Filters profiles based on the standard.
Note: You can set which standards will be visible in the BIM Profiles panel in the Settings (Profile's standards). By default all standards are visible.
Search bar
Search for specific profiles using the search bar.
