-LAYER command
Manages layers through the Command line.
Alias: -LA
Creates layers and layer states and changes their properties.
Options within the command
- ? to list
- Lists the names of layers in the current drawing.
- New layer
- Creates new layers.
- Make new current layer
- Creates a new layer and then makes it current.
- Set layer as current
- Sets a layer as the current one.
- Rename
- Renames the layer.
- Color
- Changes the color of layers.
- Linetype
- Changes the linetype of layers.
- LineWeight
- Changes the lineweight of layers.
- TRansparency
- Sets the entity transparency factor between 0 (fully opaque) and 90 (fully transparent).
- MATerial
- Sets the material property for all entities on the layer.
- Plot
- Changes the plot status of layers.
- stAte
- Manages layer states.
- Save
- Saves the current layer state.
- Restore
- Restores a saved layer state.
- Edit
- Edits a saved layer state.
- reName
- Renames a saved layer state.
- Delete
- Deletes a saved layer state.
- Import
- Displays the Import Layers States dialog box, which allows you to import a layer state from a file into the current drawing.
- eXport
- Exports a saved layer state in the current drawing to a layer state file.
- turn layer ON
- Turns On layers that were previously turned Off.
- turn layer OFf
- Turns Off layers to hide their entities from view.Note: When you select the current layer to turn it Off, a warning prompt is displayed in the Command line. It allows you to choose between Yes-turn current layer off and No-leave current layer on.
- select entities
- Allows you to specify the layers using an entity selection.Note: The selection of entities is available only for turn layer OFf, Freeze, Lock, Unlock, and Description options.
- Freeze
- Freezes layers so that they are hidden from view.Note: The current layer can not be frozen.
- Thaw
- Thaws layers that were previously hidden with the Freeze option.
- LOck
- Locks layers so that their entities remain visible but cannot be edited.
- Unlock
- Unlocks layers that were previously locked.
- Description
- Allows you to set the description property value of existing layers.
Enter the description, then enter the name(s) of the layer(s) to apply the description to. When listing multiple layer names, separate the names with a comma (,).
Note: When you type a description to a layer that already has an existing description, a warning prompt is displayed in the Command line. You can choose to replace the existing description or not.
- rEconcile
- Sets the unreconciled property of one or more unreconciled layers. When listing multiple layer names, separate the names with a comma (,).
- Xref
- Resets the XRef layer property override in the current drawing to the layer settings in the XRef.Note: The VISRETAIN system variable:
Controls the visibility, color, linetype and lineweight of an XRef, and if path changes to nested XRefs are saved. If the PSTYLEPOLICY system variable is off (0), also controls the plotstyles of XRef-dependent layers.
- If Off (0): Changes made to XRefs-dependent layers in the current drawing are valid in the current session only and are not saved with the drawing. When the current drawing is reopened, the layer table is reloaded from the reference drawing and the current drawing reflects those settings. The layer settings affected are On, Off, Freeze, Thaw, Color, Ltype, LWeight, and PStyle (if PSTYLEPOLICY is set to 0).
- If On (1): Layer settings are saved with the current drawing's layer table and persist from session to session.
