-LAYER command
Manages layers through the Command line.
Alias: -LA
Creates layers and layer states and changes their properties.
Note: The current layer cannot be turned off and frozen.
Options within the command
- Lists the names of layers in the current drawing.
- New layer
- Creates new layers.
- Make new current layer
- Creates a new layer, and then makes it current.
- Set layer as current
- Sets a layer as the current one.
- Rename
- Renames the layer.
- Color
- Changes the color of layers.
- Linetype
- Changes the linetype of layers.
- LineWeight
- Changes the lineweight of layers.
- TRansparency
- Sets the entity transparency factor between 0 (fully opaque) and 90 (fully transparent).
- MATerial
- Sets the material property for all entities on the layer.
- Plot
- Changes the plot status of layers.
- stAte
- Manages layer states.
- turn layer ON
- Turns layers on that were previously turned off.
- turn layer OFf
- Turns layers off to hide their entities from view.
- Freeze
- Freezes layers so that they are hidden from view.
- Thaw
- Thaws layers that were previously hidden with the Freeze option.
- LOck
- Locks layers so that their entities remain visible but cannot be edited.
- Unlock
- Unlocks layers that were previously locked.
- Description
- Allows you to set the description property value of existing layers.
Enter the description, then enter the name(s) of the layer(s) to apply the description to. When listing multiple layer names, separate the names with a comma (,).
A warning prompt is displayed when you list a layer with an existing description.
- rEconcile
- Sets the unreconciled property of one or more unreconciled layers. When listing multiple layer names, separate the names with a comma (,).
- Xref
- Resets the XRef layer property override in the current drawing to the layer settings in the XRef.Note: The VISRETAIN system variable:
Controls the visibility, color, linetype and lineweight of an XRef, and if path changes to nested XRefs are saved. If the PSTYLEPOLICY system variable is off (0), also controls the plotstyles of XRef-dependent layers.
- If Off (0): Changes made to XRefs-dependent layers in the current drawing are valid in the current session only and are not saved with the drawing. When the current drawing is reopened, the layer table is reloaded from the reference drawing and the current drawing reflects those settings. The layer settings affected are On, Off, Freeze, Thaw, Color, Ltype, LWeight, and PStyle (if PSTYLEPOLICY is set to 0).
- If On (1): Layer settings are saved with the current drawing's layer table and persist from session to session.
