LCONNECT command
Creates or modifies an L-connection between solids.
Icon:
Creates or modifies an L-connection between solids. Optionally disconnects L-connected solids.
Before | After |
Options within the command
- Select entities to connect
- Manually select the two entities you want to connect.
- Switch
- Allows to choose between two butted L-connections:
or a mitered L-connection:
or a touching (disconnected) connection:
