MINSERT command
Inserts a block as a rectangular array.
Inserts a block as a rectangular array. It is a combination of the –INSERT and -ARRAY commands and creates a MInsert Block entity.
Options within the command
- Block to insert
- Specify the name of the block to be inserted.
- Displays the Insert Block dialog box.
- Insertion point for block
- Specify the insertion point of the selected block.
- Scale
- Allows to set the X and Y scale factor equally.
- Corner
- Specifies the size of the block by picking a second point.
- X scale
- Specifies the scale factor of the block in the x direction.
- Y scale
- Specifies the scale factor of the block in the y direction.
- Z scale
- Specifies the scale factor of the block in the z direction.
- Rotate
- Specifies the rotation angle of the block around its insertion point.
- Multiple blocks
- Allows to insert a rectangular array of multiple blocks.
- Number of rows in the array
- Specifies the number of rows.
- Number of columns in the array
- Specifies the number of columns.
