POINTCLOUDCROP command
Creates a crop boundary on a point cloud.
Icons:
Creates a crop boundary on an attached point cloud, displaying only the part of the point cloud inside or outside a prismatic or cylindrical volume.
Method
If the current drawing has more than one point cloud attached, you are prompted to select which point cloud to crop.
If the current drawing has only one point cloud attached, it is automatically selected for the crop operation.
You can then immediately start selecting points based on the previously selected crop option (shown as <default>).
Alternatively, select a different crop option and proceed with the points selection.
Note: The command automatically turns off the Perspective view mode. To turn it back on, select it in the LookFrom control or set the PERSPECTIVE system variable's value to 1.
Options within the command
Rectangular
Creates a rectangular prismatic cropping.
Note: The crop boundary creates a rectangular volume of points perpendicular to the view in which you defined it.
Polygonal
Creates a polygonal prismatic cropping.
Note: The crop boundary creates a polygonal volume of points perpendicular to the view in which you defined it.
Circular
Creates a cylindrical cropping
Note: The crop boundary creates a circular volume of points perpendicular to the view in which you defined it.
Invert
Inverts the current cropped part. Switches between Inside and Outside.
Inside
Displays the part of the point cloud inside the volume only.
Outside
Displays the part of the point cloud outside the volume only.
show Toggle
Turns the current cropping on or off.
remove Last
Removes the most recently added cropping volume.
remove All
Removes all cropping.
