POINTCLOUDMODIFYCLASS command
Adds points to a point cloud class.
Allows you to select points in a point cloud to assign to a different class.
Note: Use the POINTCLOUDCLASSIFY command to automatically classify points in a point cloud.
Method
After launching the command, the indexes of the available classes are listed in the upper field of the Command line.
Enter the index of the class under which the points will be classified.
Choose the points selection type, select the points, then pres Enter to confirm the selection.
Options within the command
- Rectangular
- Activates the rectangular selection type.
- Polygonal
- Activates the polygonal selection type.
- Select
- Allows you to add more points to the selection set.
- Finish
- Finishes the selection process and classifies the points.
