POINTCLOUDMODIFYFLOOR command
Adds a floor or modifies existing ones.
Adds a floor (spatial classification) to a building or modifies the volume of the specified floor by moving the faces of a temporary crop solid.
Options within the command
- Add
- Adds a new floor to an existing building. Specify the building index as listed in the Point Cloud Manager panel or Spatial Locations Manager dialog box.Note: The Add Floor option from the context menu of a building listed in the Point Cloud Manager panel runs the Add option of the POINTCLOUDMODIFYFLOOR command.
- Edit
- Modifies the volume of a floor of an existing building. Specify indexes as listed in the Point Cloud Manager panel.
Move the faces of the temporary crop solid.
Note: The Modify option from the context menu of a floor listed in the Point Cloud Manager panel runs the Edit option of the POINTCLOUDMODIFYFLOOR command.
- adjust Elevation
- Adjusts the elevation of the temporary crop solid.
- adjust Height
- Adjusts the height of the temporary crop solid.
- Done
- Assigns the points in the temporary crop solid to the specified floor and exits the command.
