POINTCLOUDPROFILESWEEP command
Reconstructs a linear feature in a point cloud.
Icon:
Reconstructs a linear feature in a point cloud by connecting a set of profile key points in consecutive cross sections of the point cloud. The detection of the profile in the next cross section can be automatic or manual.
Method
Launch the command to open the Point Cloud Profile Sweep command context panel.
Note: To improve the selection of relevant point cloud points, turn on the Point Cloud Nearest Point entity snap (see the PCNEAREST command article).
In the model space:
- Click a point in the point cloud near the linear edge to reconstruct to define the start position.
- Click a second point in the point cloud to approximate the direction of the linear edge. This direction will be refined in the next steps.
- Click any grip point, drag it, and click again to change the position, size, or direction of the profile section.
In the command context panel:
- Click inside the section preview to add or edit key points.
- Control the step settings.
- Start or pause the stepping process.
- Choose the desired output format.
- Click Accept to create the profile entities according to the stepping preview or click Cancel to exit the command.
Options within the command context panel
- Profile preview
- Allows you to add points to define the step profile.
- Left-click to add key points.
- Right-click to remove key points.
- Click, hold and drag a key point to reposition it.
- Use the scroll wheel to zoom in or out.
- Hold middle-mouse button to pan.
- Use the slider or the control buttons to select a step.
- Step controls
Run- Starts or resumes the stepping process with the current settings.
- Options
- Accuracy
- Sets the stepping process accuracy threshold.
The stepping process stops when the key-point match score is below the chosen threshold. To resume it, adjust the threshold or keypoints, or add a manual step.
Note: The options in the Command line reflect those in the command context panel.
Adjust key points in step profile
Close profile
Pause
Invert
Camera aligned
Remove steps
